I have an 89 ford bronco and would like to do a straight axle conversion i have a dana 44 from a 78-79 pickup what else do i need i want to run 38-40s on this thing.I'm not impressed with the ttb.any help would be appreciated
I agree and would add "without upgrading to stronger axleshafts and other components". I'm running 38's on my 78 Bronco, with 4.88 gears, spooled 9" Currie rear, open front. I've had to upgrade to chromoly axleshafts in the front D44 to keep from constantly breaking the stock ones. I also just overhauled the 9" rear brakes, axle bearings and seals. A Dana60 is more suitable for 35" or taller tires. I'm only running 36" tires on the 84 Bronco with the D60 SAS. You don't always have a choice on what to use and may go ahead with what you have in the D44, then upgrade later if your driving style keeps breaking stock parts. Miesk5 posted some great info and links from his webpage, JSM84I would not recomend running that big of tires with that running gear
