89 bronco tranny swap
bushwhack7732
Central NY
Ok so i have a M5OD transmission that came off an 89 f150 with a 300. And my bronco is an 89 xlt with a 351W. Question is if i go through hangin the clutch pedal and all the horse shit associated with an auto/manual swap, would i be able to bolt up this tranny. And with that would i have to do any sort of rearend swap too?
that is the same bell housing bolt pattern. diff is unaffected but you may need to modify the driveshaft lengths. Also you will need a flywheel for the 351
Sufferedformula
