89 bronco 4.9 liter 6 cylinder idle problem
smokeysbronco
My 89 bronco is running rough at idle but fine at higher rpms I have changed the plugs,wires,cap,rotor,fuel filter.and aic valve on the fuel injection. run great going down the road just when idling very ruff what should i check next?
yo SMOKEY,
WELCOME!
Try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
http://broncozone.com/topic/14269-code-reader/?&pid=74587&mode=threaded
Run it around to heat the engine up and shift thru all gears incl Reverse. Then turn off all accessories/lights, etc.
Do Key On Engine Off (KOEO) portion first.And Post em here according to:
KOEO
KOER
This if for rough idle in a 94, but process is same
http://www.thedieselstop.com/faq/9497faq/maint/vra/vra07015.htm#vrachart9
For vacuum issues;
see Vacuum Line Acronyms, leak test & gauge pic OCT 2013 at http://broncozone.com/topic/23994-90-58l-getting-continuous-code-33-and-running-code-44/
post #20
Mgough
