84 5.0 monster bronc
Biged
[-o< Killer truck 302 4bbl highrise edlbrock 84 wont accept gas filler tube backs up after two gallons
shyguy
Newfoundland, Canada
23755[/snapback]
I have that same problem with my 90 bronco....the mechanic I talked to said it has to do with the vent pipe....if there's any blockage, it'll act funny after so many fumes trying to leak out....I got mine fixed and haven't had a problem since
bluesman17
Spam Terminator
South Bend, Indiana
When my tank strap broke and tore the filler tube up i accidently kinked up the vent while putting a new filler (wasnt formed so that didnt help)tube on and it took like 10 minutes to put in 5 dollars worth, and when i cut off the straight one to put a junkyard one on i slashed the vent in half by accident but it fills fine now. Just cant keep going once the gas pump kicks off unless i want to get hosed. Good luck and be safe around the tank...
wrachet
Kansas City Area
Same problem here...drives me crazy! I just try to back the nozzle out a bit and go from there!
Colleen
That is usually caused by the vent pipe comming loose and not being in place. You have to remove the filler tube and reattach the vent pipe that is inside the filler pipe. It's about a 1/2 hour job. If you need a proceedure let me know.
shyguy
23803[/snapback]
Sure, give me the procedure for it just incase it happens again.....you never know what mechanic will ***** around with the truck next.
