ok so i have a 1978 bronco with a 351m that i bought that had sat for 3 years witout running. i had the carb rebuilt put new fuel lines on with sending unit, fuel lift pump, cleaned and gapped spark plugs, replaced ignition coil, and threw a new battery in. well i drove it for about 2 weeks then it just died. well i can turn it over and it will fire and run for about 2-3 seconds then stall and wont start for about another five minutes then it wont hold an idle...well its getting fuel and the only thing i can think of being the problem is the i c u....is that correct?
