user456101
Where to start .... 1974 Bronco was driving slow - wouldn't go more than 35 mph, then something popped and then no power to the wheels at all. Motor runs absolutely fine, but shift it into gear and nothing, absolutely nothing. No rattle, no scrape, no crunch, no squeel, no nothing. Nothing moves underneath as far as I can tell. The drive shafts are fine I think - will turn 1/8 of a turn and stop. Same symptom in both 4WD and 2WD but the shifter moves pretty easily between them - too easily? Broncos are completely new to me. This is my soon-to-be son-in-law's, and he has never worked on it. Where to start? Pull off the transfer case and the transmission and take a look? Throw in the towel and have someone just replace one or both? What should I try first or what do I need to know before proceeding? I think it is a pretty original (in-line 6cyl, 3 on the tree, drum brakes all around) vehicle. If it makes a difference, he would like to switch to automatic transmission anyway - now a good time to go ahead and do this? He also wants to go 4-wheel discs. He has had it 10 years, since he was 18, but has never made progress on it. Now he has some money but not the time or space to work on it himself so I offered to do some footwork for him and I am handy with a wrench so I can work on it as well.
