5.0 ** Out Of Mark Ii
4XFLOORED
Is this a good engine>? will it work in my 69 ? or is there a better motor to go with? :blink:
Shwagy357
good motor same as mustang 5.0 ** except it has speed density as oppossed to mass air. If one were into making assumptions you could assume that the mark would have been less likely to have been ambussed.
STLKIKN
Calgary Alberta
The Mark should have smaller injectors, and speed density...
Your local Mustang speed shop should either have a conversion to mass or can tell you how to wire it into the Marks harness.
79' Buckin Bronco
