302 and 351 head/intake swap
Thadoggma
Redmond, OR
ok i want to swap my 302 h.o. heads with some 351 heads to get a little more power out of my bronco. im wondering what else will i need, obviously new intake and exhaust. my new setup will be carbureted instead of efi. anyway what kind of heads (351w, 351m or 351c) will i need and is there any mods i have to make to get this to work? thanks for your help...
wtfdissux
Buffalo, NY
in my oppinion the job is not worth the result either swap the whole motor or just live with the wimpy little 5.0
The 302 heads use 7/16 head bolts and the 351w heads use 1/2 inch head bolts so to put 302 heads on 351w you have to drill the holes out to 1/2 and to use 351 heads on a 302 you have to get these special step washers that edelbrock makes . Unless you the set of heads you want to swap in has a way better combustion chamberdont waste your time the valves are the same size and they wont flow any better . I put 1986 5.0 ** heads on my 351W and it runs very good but the combustion chamber is more of a swirl design so it had definate benefits . :D /emoticons/[email protected] 2x" width="20" height="20" />
wtfdissux
Buffalo, NY
on the same token has any one tried to put the intake from a 351 lightning on a 351 bronco and if so what has to be done and what would the benefits be on that set up?
Virgil3rd
