2 diffrent hub assemblies cant figure out how to do one side
Justbust1n
walkertown
i have a bronco with two diffrent hub assemblies and i know how to do the side with the spindle nut, but the other side has like a big bolt and i cant figure out how to get it off there in no real way it looks like ??? does ne one know what i am talkin about ... its not the spindle nut cause i even have the socket for that with the teeth , its the other kind ..... ne input would be greatly appericated...
sam2002
Is iit the large nut that sits deep inside the hub?
if so you have to buy a special socket ,called a lock nut socket .I found one at pep boys automotive it was around 14 bucks ,they are vehicle specific applications so look at the back of the package before you buy one and make sure it will fit your year bronco
hope this helped
good luck
Justbust1n
Justbust1n
walkertown
Is iit the large nut that sits deep inside the hub?if so you have to buy a special socket ,called a lock nut socket .I found one at pep boys automotive it was around 14 bucks ,they are vehicle specific applications so look at the back of the package before you buy one and make sure it will fit your year bronco
hope this helped
good luck
yeah thats it wanted to know how you get it off?
Roadkill
Killeen, TX
If it is the kind with flat sides, you can try to wedge something inside between the flat side and the inside of the hub. Then put something between the lugs to turn the entire hub pulling the nut around the spindle with it. Just be carefull of threaded parts when doing this, the point is to get the nut off with out damaging other stuff you will then have to fix. I know this will sound dumb and I'm not trying to take a jab at you but you will probably want to replace the oddball stuff to match the other side when you put it all back together.
Good luck
Justbust1n
Justbust1n
walkertown
Good luck
yeah i am deffinatly gonna put some spindle nuts in the other side , i think it was wreck b4 i bought it and the person that did the other side went ahead and put the spindle nuts on ther and i am fine with doing them but i cant figure out how in the **** to get this big bolt off ... i mean it looks like a cresent moon lockin type object holdin it back , man i wish i had my camera but atleast a couple of you guys know what i am talkin about ... so you sayin to take someting and get behind the bold and turn the whole assembly??? what can i fit in that small of a place?
Roadkill
Killeen, TX
Try a piece of wood (preferably a hard wood like oak) or maybe two pieces; one to fit down into the space up against the flat and one more to wedge in between the first piece and the curved metal wall to make it all tight. Depending on how tight the nut is on there, that may get it off.
I hope I described that well enough for you figure out what I mean. I've done it before and it's perfectly clear in my eyes :-B but it's hard to put into words. :mad:
Roadkill
Killeen, TX
One more idea. Since you dont plan to reuse the nut, it won't matter if the nut itself gets a little messed up. So...
If you have the room in there to manuver, try using a small cold chisel and a hammer to tap it in the direction you need to go. Set the chisel so it cuts into the edge of the nut very close to one of the points. (on the right side of the point assuming it is a right handed thread) When it's set then angle the top of the chisel slightly to the right and hit it towards the left. This method will mess up the nut but you plan to replace it any way.
From what you have described, I am not understanding why you cant just put a big ass socket on it. Is there more to it or do you just not have a socket big enough?
Justbust1n
Justbust1n
walkertown
yeah its a HUGE socket i wish i had a camera ... so you could understand...
Roadkill
Killeen, TX
Sockets like that are obviously available somewhere since someone installed the nut in the first place and I used to use sockets like that to work on Army 2 1/2 tons. I don't know where to get one though and it would probably cost more than I would be willing to pay for a tool that you will only use once.
Justbust1n
Justbust1n
walkertown
finally got it off there was a lock type cresent moon washer on there i had to pick off with a bent fork i made , then i had to take a hammer and ***** driver and tap it until it cane off no problem ..... thancx guys for the input now for the bearings!!!
Roadkill
Killeen, TX
Congrats! And now you have another home-made special tool for your collection. I have a box full of homemade devices to get certain parts off of various vehicles I have owned. I think mechanical engineers should be forced to actually work on the stuff they design. Someday, my grand-kids will get to play "What the heck did he use this stuff for" when they divy up my stuff.
Justbust1n
Justbust1n
walkertown
hahahaha , amen, man, amen
Justbust1n
Justbust1n
walkertown
well guys finally got the bearings on and actually i forgot how da%@ hard it was to get the outter bearin to seat right took me a couple of poundings and pushes to get it on right. then packed that baby full of grease and slapped that hub on ... wish i had enough money right now to have done the brakes but ow well ... point of refrence of you have this kinda bolt make sure you get the lock ( cresent moon type ) off or it will strip the spindle ... thanx you guys for the help
seansz28
