1996 bronco eb 5.8 what are stock differentials?
joshmccln
fernandina beach
starting to do a little more off roading and i was wondering if someone could tell me what is the stock differential that comes in the front and rear of a 1996 bronco ed 5.8
Welcome to Bronco Zone!!! The axles would be a Dana44 TTB (TwinTractionBeam) front, with a Ford 8.8" rear. Check some of the pinned topics for info on axle codes and gear ratios, JSM84
joshmccln
joshmccln
fernandina beach
thanks man ill look into it i knew that the back was a 8.8 but was not sure on the front had only chevys so far except for a 92 bronco that i had untill i ran into a tree three months down the road i kinda new to the ttb
joshmccln
joshmccln
fernandina beach
yea looked up the axle code and found out it was open diff which brought a tear to my eye. cant believe a eddie bauer would have a open diff i was hoping for a ls but thanks for the help
joshmccln
joshmccln
fernandina beach
off the door the axle code is 19 the metal tag is still on the diff but didnt bother to check it cause i figured it would tell me the same thing non ls with 3.55 gear ratio but if i am wrong please let me know
yo!
19 is the 3:55 "open" diff for the 8.8
Now, to verify that the 8.8 is Still there; look @ this 8.8 Cover Depiction
Source: by Ventures Truck Parts and Equipment L.C.
If not; then match it up to others, such as the good old 9" and Dana 60 etc by Ventures @ http://www.venturesparts.com/index.php?page=rear-axle-identification
Yes, you and Miesk5 are correct, 19 or I9 is "open" 3.55 gears. You have the option of adding the trac-Lok limited slip or swapping in a carrier, ring & pinion from an H9 or factory L/S rearend. The better option is to add a new unit, as the factory ones are often worn out and need new clutches. Whatever the case, it would help out to have at least rear limited slip for offroad use. IF you plan to add a lift kit and run taller tires, when you go to re-gear the axles would be a good time to add the L/S or even a locker. JSM84
joshmccln
joshmccln
fernandina beach
yea i think im going to go with a posi but gonna look around at some more reviews because its my dd im gonna be puttin them on and as far as ring and pinion go i would be amazed if they were 3.55's because im able to turn 35" mt's over on concrete so im probly just gonna leave them alone and get a 3.93 and down posi diff......at least this is what i have been thinking
4by4
Guest
I just got a 1996 ford bronco XLT 351 w motor with 200'000 miles don't smoke yet. Thing about rebuild the motor starting then rebuild  transmission . Thing about royal purple 75/ 90wt in both differentials . What anybody think about using royal purple in axels????
Yo 4by4,
We bought our 96 new and have used just what Ford recommends.
See info in 96 Bronco Workshop Manual, partial at http://www.diesel-dave.com/vehic/manual/stj/stjleft.htm
Section 05-03A: Axle, Front Drive, Dana Models 44 and 50; Use 4x4 Gear Oil F1TZ-19580-A or equivalent meeting Ford specification WSL-M2C191-A. Add 0.089L (3 ounces) of Ford Friction Modifier F3TZ-19B546-MA or equivalent meeting Ford specification WSP-M2C196-A, if equipped with Limited Slip (Dana 44 IFS Only).
Section 05-03D: Differential, Front Drive, Dana Model 44 Limited Slip
1996 F-150 4x4 Front Axle Vehicles Workshop Manual
Lubricant Specifications
Description
Part Number
Specification (Ford)
4x4 Gear Oil
F1TZ-19580-A
WSL-M2C191-A
1.7l (3.6 Pints)
F3TZ-19B546-MA
WSP-M2C196-A
0.089l (3 Ounces
Section 05-02G: Axle, Integral Carrier, 8.8-Inch Ring Gear
1996 F-150 and Bronco Workshop Manual
SPECIFICATIONS
All conventional and Traction-Lok® axles use Premium Rear Axle Lubricant, XY-80W90-QL or -KL or equivalent meeting Ford specification WSP-M2C197-A plus 4 ounces of Ford Friction Modifier F3TZ-19B546-MA or equivalent meeting Ford specification WSP-M2C196-A for complete refill of Traction-Lok® rear axles.
b Lubricant levels are determined by filling the axle 6.4-14.2mm (1/4 to 9/16 inch) below the bottom of the filler hole with vehicle in a level position.
Note: Rear axle **** quantities must be replaced every 160,000 km (100,000 miles) or if the axle has been submerged in water. Otherwise, the **** should not be checked or changed unless a leak is suspected or repair required.
TAKE A FEW MINUTES TO REGISTER
david@holycitytransportat
