1993 Bronco power door lock issues..
Bngeejmpr
New to the Bronco world. I have a 1993 XLT, the power door locks barely worked so I replaced the Door Lock Actuator Motors on each door. The old motors looked awful, covered in dirt and muck. The new ones struggle to work. What else can I do ?
Yo Bngeejmpr,
Check connectors internally for corrosion and tightness.
F2 CHECK GROUND CIRCUIT AT RH SWITCH
Power Door Locks, F-Series and Bronco, Except Crew Cab
  • Using an ohmmeter connected to a known good ground, connect second lead to Circuit 57 (BK) at Pin 1 and Pin 5 on left door lock switch connector.
  • Measure resistance of each circuit.
Is resistance 5 ohms or less?
Yes
No
REFER to Door Lock Switch under Component Tests in the Diagnosis and Testing portion of this section. SERVICE as required.
SERVICE Circuit 57 (BK) for open circuit. RETEST system.
Power Window and Power Door Lock Switch Connector, Master, Left
Pin Number
Circuit
Circuit Function
57 (BK)
Ground Circuit
119 (PK/Y)
Lock Motors Feed/Return
171 (BK/W)
Power
120 (PK/LG)
57 (BK)
Ground Circuit
6
313 (W/Y)
Front Window Regulator Switch (LH) to Front Window Regulator Motor (RH)
57 (BK)
Ground Circuit
227 (Y)
Left Window Regulator Switch to Left Window Regulator Motor
9
57 (BK)
Ground Circuit
10
400 (LB/BK)
Power
400 (LB/BK)
Power
57 (BK)
Ground Circuit
13
314 (T/LB)
Left Front Window Regulator Switch to Right Front Window Regulator Motor
14
57 (BK)
Ground Circuit
15
226 (W/BK)
While we're in the doors;
Power Window and Power Door Lock Switch Connector, Right
Pin Number
Circuit
Circuit Function
120 (PK/LG)
Door Lock Switch (Unlock)
118 (PK/O)
Door Lock Motor (Unlock)
171 (BK/W)
Power
117 (PK/BK)
Door Lock Motor (Lock)
119 (PK/Y)
Door Lock Switch (Lock)
6
333 (Y/R)
Window Regulator Switch to Window Regulator Motor
314 (T/LB)
400 (LB/BK)
Power
9
313 (W/Y)
Left Front Window Regulator Switch to Left Rear Window Regulator Motor
10
334 (R/Y)
Window Regulators
The door window regulators should be properly lubricated to provide ease of operation. The window glass mechanism should be lubricated whenever the glass channel or window regulator is removed, or excessive effort is required to operate the windows. To lubricate a door window mechanism, apply an even coating of Multi-Purpose Grease D7AZ-19584-AA or equivalent meeting Ford specification ESR-M1C159-A and ESB-M1C106-B to the window regulator rollers, shafts and the entire length of the roller guides as illustrated by the shaded areas.
I like the skyjacker m95s and others here like the bilstein 5100 or 7100s.
➡️Find out if speed control, if equipped, recall work completed by a dealership. Call local dealer or register and view status @ https://owner.ford.com; or @ https://vinrcl.safercar.gov/vin/ ... have VIN ready.
The affected vehicles were previously repaired using a wiring harness that is not compatible with the vehicle circuit polarity. As a result, the fuse is located in the output circuit rather than in the intended input power feed circuit, and may not offer the intended protection in the event of an electrical short to ground. This could result in an underhood fire. Dealers will install a new wiring harness, or replace the mating electrical component. east302 provided following for his 93 "I found the recall information on alldata...didn't know it was even there so that's a plus. Mine has the updated harness with two fuses instead of one, so it looks like the recall was addressed correctly."
Use this guide by jowens1126 @ https://www.fullsizebronco.com/forum...ml#post6530073
Note that the 93 recall is different that the other years.
Here is the 1993 Bronco Dealer Brochure in Google Drive @ https://drive.google.com/file/d/0B-x...NNcGprQTA/view
1993 Bronco Dealer Training Video via silver70 @ https://m.youtube.com/watch?feature=...&v=Fvne3bosE3s
1993 Bronco, Venezuela Commercial @
Free registration for some wiring diagrams (86 through 96) and Technical Service Bulletins, (80 through 96), same as by Ford @ BBB Industries- Premium Alternators, Starters, Power Steering Products | TSB's & Wiring Diagrams
GL!
Bngeejmpr
Thank you for the information ! You have been a great help !!!
