1980 Bronco Axle Swap
BLUEOVAL81
:unsure: I CURRENTLY HAVE A 1980 BRONCO WITH A 4 INCH SUSPENSION LIFT AND WANT TO SWAP TO A DANA 44 SOLID AXLE WITH THE SAME HEIGHT LIFT. CAN I USE THE SAME DROP PITMAN ARM, THE DROP RADIUS ARM BRACKET, THE SAME SPRING BUCKETS AND COIL SPRINGS FROM THE TTB SUSPENSION. AND ALSO CAN I USE THE STOCK RADIUS ARMS FROM A 78 OR 79 BRONCO.
mindy
