No Power
mtneerfan
I pulled my 76 in to the garage and parked and now I have no power. It will not start and I have no power to the lights or anything else. I replaced the battery and the lights worked. I tried to start it and it turned over briefly and now the nothing works. Any ideas?
What else have you checked..?
For starters..,
Check batt. cable conn. at the batt. & the block (ground)
----" ----" -----" ----" --- at the solenoid & starter (pos.) & all connections on the solenoid.
mtneerfan
mtneerfan
:lol:
What else have you checked..?For starters..,
All the cables were hooked up tight and the cables were in good shape. I cleaned some rust from the cable that run from the battery to the solenoid with some sandpaper and everything is working fine. I thought for sure it was something alot more complicated. Thanks.
"I cleaned some rust from the cable that run from the battery to the solenoid with some sandpaper and (now)everything is working fine. I thought for sure it was something alot more complicated. Thanks."
---- You're welcome.., & as a side note;
A good percentage of the problems on older rigs can be solved by that very serv./maint. proceedure, on several wiring connections, from headlights to tail-lights & most everything in-between.
Gary wilder
