EEC IV Diagnostic Devices
beach8
Does anyone know if The above Rotunda Superstar II 007-0041a Will properly pull codes and do diagnostics on a 90 full size bronco 4.9L (300 cid), with EEC IV, I have a chance to get one at a good price but don't want to bother if it wont cover my car, I have a brainmaster 2000 model 3226 but it wont work on a 90 + and can't be updated, I've got an intermittent code and would like to fix it. Any help would be appreciated
Aaron
yo!
Save your $$ and do the Self Test by our pal BroncoJoe19
do both Key On Engine Off (KOEO)
Key On Engine Running KOER self tests - engine must be @ norm op temp....
Post Codes here
or look in my broncolinks.com site
and read a few Links that begin with;
DTCs 2 digits & some Possible Causes; MANY CODES!
btw, here are the test inst for it;
"...Using Super Star II Tester, Rotunda 007-0041A
Turn the ignition key off.
Connect the MECS adapter cable, Rotunda 007-00038, to the Star Tester.
Connect the adapter cable leads to the blue 4EAT STO and STI connectors. (Located under the dash on the left side of the steering shaft.)
Ground the adapter cable.
Slide the Star Tester switch to the MECS position.
Latch the center button in the test position.
Turn the ignition key on.
Turn the Star Tester on. It will sound and display an "888" for two seconds.
Unlatch and relatch the center test button.
Record codes, then unlatch the center button..."
The sSelf Test is just as good and cheaper!
GL
beach8
Aaron
Thanks just used to having the old hand held device and the price was right, i'll try it your way and save bundle on the runstinbronco, I still even have a breakout box
Aaron
YW Aaron,
Wow, a breakout box..now that is handy!!!!!!!!!!!!!!!!!!!!!!!!!
Wish I had one while TS my 4WABS Controller and harnesses!
GL!
