You'll have to back-track through the circuit to find out where you should have power, but don't and then keep following the circuit until you find that you do have power. When you discover that you have power, then the break in teh circuit is likely in the last length of wire, switch, or connector that you checked.
So I am thinking that in your circuit, you'll have the battery, then the fuse(s)? then the ignition switch, then the fuel inertia safety switch, then the fuel pump relays (there are two of them, one for each pump) then the pump(s) and associated grounds.
If I were doing this... the first place I would check for power is at the relays at the battery side of the big connectors. Then with the key ON at the big connector on the fuel pump side of the relay(s).
I'd start there because it is pretty much in the middle of the circuit, and is by far the easiest place to get to. One can do it standing up!
/emoticons/
[email protected] 2x" width="20" height="20" />
