"ok so its a hydrolic assist"Well, yes & no...all power steering is "hydraulic"----yours is simply a "mix-n-match" power steering set-up.
".. steering column i have no idea what its off of but its not the right one and is loose as ****."
Steering column is everything fr. the steering wheel down thru the firewall to just a few inches past the firewall, under hood... Are we on the same page here..? If so, are you saying all of this wiggles..?
"i cant find any parts for it anywhere, or even what kind it is or what it came off of"
This info isn't going to jump out atcha..! It's going to take some effort. Stop at a good auto parts store & they will identify these items for you.
"it leaks like a siv, so im thinking it would be easier to just buy a different pump"
Now exactly what are we talking about here..? The "pump" is the round thingie on the eng. with a v-belt & pully.
Sooooo..., where is it leaking from...the pump.., the hoses.., or the steering gearbox..?
".. i could rebuild the bell joint and i think that would take care of that."
Yes.., if it's the "shaft" that's loose....not the whole column...as you stated above.
"or maybe i should just take the assist out and stick with just the manual steering box and buy a whole new steering shaft."
I'm guessing you don't have any of these parts...this solution would be nearly as expensive as a used factory pwr. steering set-up.
"i heard one off of a f100 would work?"
This isn't cheap or easy either...& the "stock" set-up is prefered.
OBVIOUSLY.., you're frustrated but these problems come with all pre-owned vehicles...especially 4x4's.
"CHILL" & take it a step at a time & have fun with it....
If I could see it.., I could tell you if it's safe & fixable...but so could any "
good" mechanic in your area.
If it's not save/repairable (cheapest way)... then I would go with a good used "stock" EB column.., new or used upper & lower shafts & U-joints.., & a "stock" power steering gearbox. (the pump, pullys, belt, hoses, & brackets are already there)
This could run in the $1000 range....or as little as $4-5 hundred.
I'm guessing your "column" is "stock" EB...but you're calling that
homemade shaft a column.
Your 1st step should be to a book store.., or the library to varify terminology, etc. This would net you much easier, faster, & more correct help. :-B
" i just bought this thing" Be careful with this.... :lol: :lol: B)
