1990 Bronco 351-W stalling problem
CntryGrl
Ok so check this out I REALLY need some help here. I have a 1990 Ford Bronco Eddie Bauer edition with a 351 windsor. My problem is I have put a new computer in it, new fuel filter, complete tune-up and the damn thing keeps stalling on me. It's not the battery because I have TWO hooked up and it's not the fuel pump because we hot wired it to test is and it works fine. SOMEONE PLEASE HELP ME!!!!!
Is it possible that it could be the Idle air control valve?
What about the voltage regulator?
I am interested in any ideas that any of you might have just please help me..
It could be a bunch of things. Including fuel delivery problems, Idle air control valve, vacuum leaks, bad EEC module, bad MAP sensor and on and on.
To help narrow it down, you should pull diagnostic codes from the computer. It can run a bunch of self tests on a various number of sensors and actuators.
Here is a link to an informative post of how to pull codes without any special tools.
http://broncozone.com/forums/index.php?s=&...ost&p=74581
C
CntryGrl
It could be a bunch of things. Including fuel delivery problems, Idle air control valve, vacuum leaks, bad EEC module, bad MAP sensor and on and on.To help narrow it down, you should pull diagnostic codes from the computer. It can run a bunch of self tests on a various number of sensors and actuators.
THank you so very much I did finally figure out why it was stalling it was the Ignition control module. I have fixed that problem and yet I still have a check engine light on so that page you set me will come in quite handy thank you again. Oh and I do know that my voltage regulator is bad so that might also be a problem however I have a new computer in it and I hope I don't fry it.
