Door Locks not working
Matticus
My power door locks are not working, I found the Power door lock actuators here, is that the only thing in the doors or is there a motor that may be shot?
JLasvegas
when you hooked them up can you hear anything when u hit the lock button
it could possibly be that the linkage is not hooked up properly
Theres no sound at all
I also have nonfunctioning electric door locks.
I bought a new one, and didn't get up the ambition to takle it yet.
The actuator is a motor that pushes and pulls a rod. It is mounted to the door near the bottom vertically. It snaps into a plastic retainer that is riveted to the door. If one opens the door, and looks below the door locking mechanism, one will see a dime sized washer looking thing that has a rivet in the center of it. That holds the plastic clip/holder that holds the actuator in place. On my bronco that plastic holder is broken on both doors. I guess I am going to have to drill the center of the rivet out, and use a bolt or something to hold the new plastic holder in place.
I pulled the actuator out and put power to it a few differnet ways to test it, and nothing happend so I guess it is bad.
I searched for a helpful thread here and didn't find one that was particularly helpful.
AS you work your way through the problem, see if you can take some pictures, and kinda write a tutorial of how you tested it, and ultimately fixed it.
I found that trying to look at the inside of the door was challenging, and ended up taking my digital camera out, sticking it inside the door and snapped a few pictures. I am not clear on how or where the actuator is suppossed to hook up to the locking mechanisim, cause the parts are lying on the bottom of my door.
If I get to it first, I can help you out... if you get there first, you'll be helping me.
good luck to both of us.
joe
raddad51
kelowna bc canada
Had pass door apart no power windows or latch. Took apart tested switchs and connector..all good.. cut power.. removed window motor to replace. Tested it worked. Cleaned up latch while there.. now pops so hard afraid its gona break. Give up on why just glad they work...
