Rear seatbelt
Blue68
Monterey, CA
I am new to the Bronco world and attempting to install a new rear seat in my recently purchased 68. The rearend has been rhino-lined and I can't locate the original seatbelt holes. Any suggestions on the location-?
If not any way do drill new ones without dropping the gas tank out?
S_bolt19
Colorado
Look from the bottom of the tub. You will probably be able to see the two outside ones because the two middle ones are under the tank. Once you find the outside ones, the inside ones will be directly in line with them. They are almost in line with the rear part of the wheel well.
Blue68
Monterey, CA
Is it possible it never had seat belt holes - no luck on the outside ones. Thanks for the reply.
rltow
Roanoke Rapids NC
see if you can see them on this pic if not I'll take a shot with markers in the holes
