muddinlate86
any one know what would give me a realy low idel(500 rpm).fixed my vacume leak but still low idel.
I might have you confused with someone else. Didn't you have timing issues also? I vaguely remember that your mechanic couldn't find your spout connector?any one know what would give me a realy low idel(500 rpm).fixed my vacume leak but still low idel.
Thoughts? Yep, by pulling that vacuum hose off, you just caused yourself a vacuum leak.yeah my earlier prob. was i had a bad dist.i cant get to a code reader right now but i was messing around and pulled the vacume line off the fuel reg.and it ideled better.any htoughts on that ?its running real rich and herd it might be the reg. just want to make sure
Bidi,Hey man, when you pull off that vaccume line make sure you plug it with something. Set your timing with that line off and then reconect it. Make sure your engine is warm. We'll see what we can do with it this weekend. Remind me to get that thing you needed off of my old t-body.
I tried googling ignition timing vacuum and fuel regulator and came up with thisI've always been told that when you time your engine with FI that you need to take that line off for some reason or another. I can't remember at the time though.
I am pretty sure that mine is at about 650, maybe a little more.what do you think would be a good idle speed ?bidibronco is only idleling at around 350 but hes set at that?
