NO codes, fuel pump runs non stop when key is on.
RebBronco
Ok boys, I have a 1990 351 powered Bronc and I have a few problems.
1. Fuel pump stays running
2. No codes in KOEO
So I have pulled and replaced my fuel regulator and filter and this is still doing this.Any ideas?
Ok boys, I have a 1990 351 powered Bronc and I have a few problems. 1. Fuel pump stays running
2. No codes in KOEO
This is one time that I am going to recommend changing a part without troubleshooting.
It is probably your fuel pump relay. it is located on your driverside wheel well.
It is about $10.
If that is bad, it should have thrown a code, but for $10 and as easy as it is to get to, I would just swap it out anyway.
RebBronco
RebBronco
Well swapped out the relay and it is still doing it :angry: Well, now that I have snow on the ground again, what should I do next?
It is about $10.
$hit! That was suppossed to be the easy answer!
I don't know... I am assuming that it is EFI and Not carbureted correct?
How is your truck running?
I would do a fuel pressure test next. Perhaps your pump is weak and although working, not really generating enough pressure to reach whatever the cut off point is.
$hit! That was suppossed to be the easy answer! I don't know... I am assuming that it is EFI and Not carbureted correct?
I did a search, knowing that I had seen this issue before and wonder what other info may be halpful.
Miesk5 suggested...
Check the EEC relay also to see if it is hanging up
RebBronco
RebBronco
She runs good.
Already replaced the EEC relay so next stop is fuel pressure. I will get back to y'all when the snow melts and I can get to the Bronco.
I did a search, knowing that I had seen this issue before and wonder what other info may be halpful.Miesk5 suggested...
