turn signals
desertbronc
Tucson, AZ
ok so the problem is that my turn signal lever dont stay on by itself, i have to hold it for the turn signal to blink.
second problem is that my left signal dont flash, just stays on, but my right signal flashes.
any advice on a resolution, do i need a new turn signal switch.
racebreedbronco
Las Vegas
both concerns could be related to t/sig. switch, for second concern, turn on 4 way flashers, check all bulbs, if one is out it will not flow enough current to flash that side
The latching tab in the turn signal switch has a tendency to break, I've had that happen twice. The only solution is to replace it.
:) /emoticons/[email protected] 2x" width="20" height="20" />
replace what, the turn signal switch.
Sorry for being vague, yes, the switch if it doesn't latch up. It is inside the joke and you need to remove the steering wheel in order to do it. Like Racebreedbronco said the lack of the lefy side flashing can be either the flasher or a bad bulb.
desertbronc
desertbronc
Tucson, AZ
ok thanks. well i turned on the hazards and the lighst dont blink together the blink alternatively.
and can someone tell me where i can get a remote for my warn winch, i found one on ebay for $50, but i just wanted a more reputable place.
desertbronc
desertbronc
Tucson, AZ
bigd1948
