New heater core in '90 Bronco, but no heat?
Xearo69
ok so the heater core was blowing antifreeze out the vents to i put a new core in there and i can feel the hoses coing into the firewall are hot, and the cover over the heatcore is warm.. but air ocmes out cold.. when i flick the tempratre control from cold to hot, does the same fan operate or does it switch to a different fan for the heater? is it something electronic or mechanical? am i goign to just swap the controls in the dash or something else? any input is accepted and im thankful!!! thanks!
Do you have A/C? If so, the controls are vacuum controlled and you may have a broken vacuum line into the control. Check the black vacuum line going in on the passenger side, it should go back to the vacuum reserve tank and a check valve, from there to the vacuum tree on the intake manifold. The same blower motor is used for A/C or Heat. With a broken vacuum line the default output is the defroster vents. The Cool / Warm control is a mechanical linkage to a flapper door that determines how much air flows through the heater coils. The attached diagram is for an 83, but very similar to the one in your truck.
2NDTOUR89
Southern Oregon
Check to see that your cable is routed correctly and did not come unhooked. I did the same thing with mine and found that I forgot to put the cable back in the same location and it made the cable just flop around and not open the heater door..
X
Xearo69
good stuff thanks.. now i have something to work with! im about to go try to install my new rear hatch motor (assuming its broken.. mabey a quick continuity check across the coils? i think jumper leads from battery is the easiest idea!)
