snowman74
:blink:
Hi y'all...
Finally taking the damn upper intake off to repair/replace fuel injector wires...running into a couple of problems...
First, I removed what I think is the EGR valve on the passenger side...bolted onto the upper manifold, right by the throttle body. Is that what it is? Anyway, the tube going into the bottom of the valve is FULL of some kind of black crap...I assume oil is getting in there some way, but don't know. Any ideas on what I need to do to fix this/prevent further build-up?
Second, I've removed 5 bolts on the outer perimeter of the upper intake manifold. Two on front, two on back, one on driver side. It still won't come loose. I ran my hand under the manifold on the passenger side, it appears to have at least one bolt under there...but for the life of me, I can't figure out what the fitting is (allen, torx, etc.). I also can't figure out how to remove it.
HELP GREATLY APPRECIATED!!!
Snowman74
Hi y'all...
Snowman74
