Horn and Cruise Control problem
rockstar1489
I have a 94 XLT bronco. My horn and cruise control stopped working..also my airbag light is on so im guessing that it isn't working either... i need help :)>-
Roadkill
Killeen, TX
I have not had trouble with any of those things in my truck. But, since all three circuits run through the steering column, I would check for a loose electrical connection on the column. If the connector(s) is/are good, I would get a wiring diagram and multi-meter and check to see if the internal parts of the column are making contact.
R
rockstar1489
i had the recall done but i think it is the clockspring..that was my first guess... would i be able to use a clockspring from a later year bronco like an 89? and how much does a clockspring go for?
yo!
Here are some clock spring replacement write-ups:
http://www.broncolinks.com/admin/admineditlink.php?index=775
ok, found this for your 94; doubt that the parts are same; ask Frod Dealer parts manager; or if I can, will ck Motor Craft Catalog later and let you know; no go; call dealer
http://www.shop.com/op/~Dorman_Clock_Sprin...s-prod-26354701
Dorman Clock Spring 1994 Ford Bronco F Series PUs
Item DOR-525-200
Was $123.74
Now $82.49
You Save $41.25
very careful with this sys. it can hurt you!
and the puller is about $18.00
plus Torx bit will prob be needed
R
rockstar1489
yo!Here are some clock spring replacement write-ups:
Item DOR-525-200
Was $123.74
Now $82.49
You Save $41.25
:D /emoticons/[email protected] 2x" width="20" height="20" /> kool thanks man hmm.. how much do you think labor would cost to have it installed...i have an airbag..
yw
Assuming Labor & Diagnostic rates of $80.00/hour;
Labor/Diagnostic Time;
Air Bag Sliding Contact, Replace (1992-95) 0.7 hours
$56.00
+ parts
so, watch estimates from Dealer or shop; don't go for a 4 hour labor estimate!
gl!
