how tight is to tight for inner and outter bears for front end
Justbust1n
walkertown
how tight is two tight for your bearings how do you guys tell when you do them just want a point of refrence....
From Haynes;
tighten the inner bearing adjusting nut to 50 foot pounds while rotating the wheel back and forth and seating the bearing.
Back off the adjusting nut approximately 45 degrees.
Assembler the lock washer by turning the inner lockout to align the pin with the nearest hole in the lock washer. To lock it, install the outer lock nut and tighten it to 150 foot pounds.
Grab the top of the tire with one hand and the bottom of the tire with the other. Move the tire in and out on the spindle. End play should be less than .006
Justbust1n
Justbust1n
walkertown
dang thanx ... is there ne thing you dont know on here......lol YOU DA MAN!!!! :)>-
