Changing front axle
Broncoforlife
Victoria, BC
I have a 1983 Full size ford bronco with dana 44 scisor axle..
I want to change my front scisor axle to a dana 44 straight axle.
What year should i take the axle out of and does anyone know what the gear ratio in the ford 8.8 was in 83?
Should i try get a certain year of axle that will just bolt right in? What year would that be.
Thanks
I have a 1983 Full size ford bronco with dana 44 scisor axle..I want to change my front scisor axle to a dana 44 straight axle.
Thanks
Probably something from a late 70's model F250. Look on the safety compliance sticker on the driver side rear door post. There is an axle code listed there. However, that is only good if the gear ratio hasn't been changed. There is also a tag on the differential that lists the gear ratio. If you are doing much with lifts and tire size, you will probably end up changing that anyway.
Here a few links you might find interesting:
http://www.drivetrain.com/Fordtrkratio_posidata.html
http://www.broncodata.com/reference/axlecode.htm
http://www.vibratesoftware.com/html_help/h...d_axle_tags.htm
http://www.off-road.com/ford/bigbroncos/tech/ratio.html
http://ringpinion.com/
http://www.angelfire.com/theforce/5ohcpa/cpa5ohtech002.htm
the '78-'79 Broncos and F-150's had straight axles. Cage Offroad has conversion kits.
Broncoforlife
Victoria, BC
I checked the number on my Driver door and it was
98-05 A035... does anyone know what gears my axle has by that?
I have no clue
Broncoforlife
Victoria, BC
on my axle it has a bunch of numbers on it that i have no idea what they mean.
3251
13W
and FOTW-4025-AA
does that help in figuring out what gears i have?
