Tailgate Lock Replacement
Bronco89XLT
Medford, NY (Long Island)
Any tips on swapping the key cylinder from 1 tailgate to another? I swapped the tailgates, but forgot to do the lock, kinda suprised me when I put the key in and it wouldn't turn :blush: TIA
It is relatively a simple job. Just be carefull not to lose any of the pieces. You will have to raise the window to the up position with the tail gate down to get at it and work from the side. Be carefull not to put any weight on the window or just to be on the safe side put something under it to support it. Then you remove a nut that holds the actuator arm on to the cylinder, a C clip, a couple of spring washers, a spring clip and the clip that holds the cylinder to the gate.
Mark the top of the lock before you remove it from the old tail gate. If you put it in upside down you will not be able to pull the key out. If that happens, take it apart turn it 180 degrees and put it back.
That is all I can think of off the top of my head.
...carefull not to put any weight on the window or just to be on the safe side put something under it to support it...
^ This! the window will need to be supported, because in the up position, it will flop around. I found out just now looking into why my tailgate lock doesn't work.
mindy
