Jimbo26
Texas
Ill be doing mine this spring. The 79 is really bad for "speaker space" without surgery. Ill make some careful choices and hope for the best! 🤞
Good luck with yours!
Cheers!
This is just a sample of how crudded up it was in there. Yes, going back 2 gens I can imagine it's even worse. Audio just wasn't that big of a concern the further back ya go.
2-tone rolled over the 46K mi. mark a couple days back. On we go!
Edit- 2/8.... The new deck was too much for the Oem front speakers & fried one already. Here we go again. 🤷‍♂️
Jimbo26
Texas
Rebuilding bosses again.
A hybrid mix should be the ticket this time around.
If this stuff is going to crater like sh💩t, then it will sure as h e l l wear the label. 😠
Jimbo26
Texas
Today was Improvements for the 'bitter half'.
Now she can get in the vehicle w/o me having to help. A fair investment in time & effort.
Grab-handle is a Toyota leftover I had collecting dust for some time. Had to dismantle & blind-nut the a-pillar for that. Kind of a tricky op, but it's handled and stress tested. Not a exact color match, but close enough for a interesting contrast.
Step-bars were el cheapo ebay units that turned out to be ok. Good install instructions which made the chore a snap. Very solid mounting.
Jimbo26
Texas
All accomplished this evening, last thing was button up the RH side. Got to the brake caliper and noticed a part of the piston was cracked. Well, that crack ended up being a Large chunk that came out in the shape of a triangle.....then a moment later, here comes the brake fluid beginning to seep out 🤬 (cue the Really bad words!) Damd composite crap they made the stuff out of. 👋💥💥💥 a product engineer again. That's another trip to the parts house.
Jimbo26
Texas
Finished up the chore and road tested today, back at it again.
All the seals for the shell appeared today. Next stretch of good weather,
I'm goin t o p l e s s .
Still too much snow and crap on the road, Frankie is still parked.☹️
Jimbo26
Texas
Still too much snow and crap on the road, Frankie is still parked ☹️
A: Twist the front hub locks to the LOCK position
B: Move transfer case selector lever to 4H or use the push-button feature, if so equipped.
C: Continue to enjoy going everywhere at a reasonable speed. 😊
Funny!
Actually, mine has vacuum hubs and auto 4x4 so no action necessary!
However, they like to pour calcium chloride on the roads to de-ice (for those who dont know how to drive)
Frankie still has factory pain and is nearly rust free (floors included)
I had fully intended to drive it year round, but I can’t bring myself to watch it corrode away!
PS my winter beater is a 2011 mustang GT, so traction definitely is NOT the issue!
Jimbo26
Texas
That's too much tech! 😬
I tend to forget that the yankee hwy depts up north of the mason/dixon line still salt everything because of the real winters. Yea, no bueno on metal. That is a exemption, as opposed to having to delouse the undercarriage after every outing.
Max undercoating!
Figured you had a late model 4X something to get around with that's mostly corrosion-proof composites.
A 'stang for winter? I can see where that would be 'fun' to get around with. One with a AWD conversion like the Hoonigan express?
Kinda makes me 😐 to have mentioned that. Was really taken back when I heard about the Block-meister a couple years ago. Just didn't seem real that a snowmobile did him in like that after living life on the edge in so many other ways.
Those gymkhana videos will live forever.
Jimbo26
Texas
BOOM-chugga-lugga-lugga💥BOOM!
Max undercoating!
It was a writeoff, BTW, its a ragtop as well! I sold of my parts broncos after Frankie was done and with the hyper inflated covid bs car market, I ended up in the stang for 0$ so I figured, what the —-! Here she isIMG_5595.jpeg
Also…RWD.
Some very off shore ice radials, and good to go.
You do have to sort of know how to drive…
Jimbo26
Texas
Also…RWD.
Still don't completely savvy how U did that but more power to ya👍
One of the better 197 examples. Must be nice.
I died trying to climb that hill (all credit to the previous regime on that)
Yes, snow/ice does take superior skills to navigate in a conventional.
Took the 'convertible' for a hop to small-town & back today. Mighty enjoyable. Windows up makes for a reasonably quiet ride.
Glad the exhaust didn't try to backwash on us- another plus. I guess the Shell🌀Effect causes that. Going to be fun for a while. That shell is a bit heavier then I expected. Now I know will need a cargo rack bar of some sort to attatch a trapeze to so getting the thing off/on will be a bit easier doing the chore solo.
Jimbo26
Texas
Here ya go, L.
The RR spot where a captive nut plate use to be.
A blind nut is close but that square shape just won't cut it. Not really sure if I can re-engineer this for a j-clip either.
Another one of those 'better ideas' that didn't pan out after 34 years. 🙄
Anybody know where to source the correct replacement?
Here ya go, L.
Hey Jimbo, I’d cut a piece of 16 ga (or so) mild steel that fits in the oval area. Drill a hole in the center to easily fit the bolt through. Then drill a 5/16” hole near both ends. Weld an appropriate nut on the backside of the center hole. Prep the oval area on the truck (shiny) put the assembly in the oval space on the truck rail and plug weld the 2 holes.
Should be perfect
Jimbo26
Texas
Should be perfect
Basically spot-weld the small holes.
Sounds doable.
I'll take that up with my old bossman- he knows his stuff about sheet metal and pretty much anything else metal work. Some of his projects have received a bit of recognition at LMC.
(I help out with the driveline issues)
Thanks for the input👍
Staff online
honesthat
