1996 Alternator Querstion
Sfayden
Kenmore, Washington
So I wanted to possibly change up the layout of the forum. I'd like to get more into the Generations and split them up a little better, especially the 1980 to 1996 Bronco forum. Any of you have any suggestions with that, or anything on the forum? Would love to hear some feed back.
I like the idea. I have a 1996 xl with ,302 really enjoying it. I do have a question ? What is the proper way to install my brand new alternator?
S
Sfayden
Kenmore, Washington
I know that I have to disconnect the battery. And the electrical connections. Then what? Is there anything I'm missing to do before I bolt it back on and start it up?
Pretty straight forward. Un hook battery like you said.
Then pull belt off.
Un bolt old one, bolt in new one.
One of the easier jobs on the old girl.
Yo
Following from 1996 Bronco/F Series Workshop Manual, partial @ http://www.diesel-dave.com/vehic/manual/stj/stjleft.htm
Section 14-02A: Generator, Integral Rear Mounted Regulator, Internal Fan Type, 95 Ampere and 130 Ampere
1996 F-Series, Bronco Workshop Manual​
REMOVAL AND INSTALLATION
Generator, 5.0L, 5.8L, 7.3L Engines​
Removal
  1. Disconnect battery ground cable (14301).
  1. Disconnect electrical connectors from generator (GEN) (10346).
  1. Remove drive belt (8620).
  1. Remove generator retaining bolts (3).
  1. Remove generator.
    Generator
    ItemPart NumberDescription
    1Fuel Filter Assembly miesk5 Note, this is incorrect. It is the throttle body plastic cover.
    (Part of 9K601)
    219703A/C Compressor
    38146Fan Shroud
    410A313Generator Bracket
    510346Generator
    6389706-S2Generator Retaining Bolts (3)
    7Heater Hose Clip
    8Heater Hose
    ATighten to 21-29 Nm
    (16-21 Lb-Ft)
Installation
  1. Install generator.
  1. Install generator retaining bolts (3). Tighten bolts to 21-29 Nm (16-21 lb-ft).
  1. Install drive belt.
  1. Connect electrical connectors to generator.
  1. NOTE: When the battery (10655) has been disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) (12A650) relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 miles) or more to relearn the strategy.
    Connect battery ground cable."
Suggest you inspect battery ground cables at block, frame and Intake Manifold to Block Strap on passenger side.
ASAP, find out if speed control recall work, if equipped was completed. If you still have concerns about Recalls, please contact the Ford Customer Relationship Center:
... have VIN ready.
To confirm current status, use this guide by jowens1126 @ 93 & 94-96 Cruise Control Recalls Repair
Note that the 93 recall is different than the 94-96 recall.
Here's the 1996 Bronco/F-Series Workshop Manual partial
96 Bronco Owner's Guide, Maintenance Schedules & Parts and Accessories by Ford @ Owner Manuals | fleet.ford.com
96 Bronco Dealer Brochure @ https://www.ford.com/cmslibs/conten...sovers/bronco/pdf/96_Ford_Bronco_Brochure.pdf
96 Bronco Quick Tips Brochure Excerpts & some Eddie Bauer options @ 1983 Ford Bronco 96 EB Bronco Brochures pictures, videos, and sounds | SuperMotors.net
mindy
