'86 Bronco XLT air cleaner ...
Emelio
Lynnwood, WA
Could anyone post a picture of the original air cleaner that came with the '86 5.8L engine? Mine came without the air cleaner being installed ;I found it inside the truck and I want to be sure is the one used on this Bronco. I've already took it apart and cleaned the rust...
Yo Emelio, for now until I and you can confirm this;
Emelio
Emelio
Lynnwood, WA
Thanks a bunch Miesk5... It looks identical to the air cleaner I found in the back of the track ;I notice the PCV valve has two fittings one going to the air cleaner "vacuum motor" ? The other one to the carburetor I suppose.. There is another small FRAM air filter inside the air cleaner case besides the main air filter. I'll be using a 4BBl Edelbrock 1906...
These drawings are of a great help since it seems that someone else was inside the engine bay before on my XLT and removed all the smog components and hoses including the charcoal canister that I intend to keep and re-install a minimum of the removed components...
Thank you again for posting this...
Emelio
Emelio
Lynnwood, WA
Thank you miesk5!
Emelio
Emelio
Lynnwood, WA
I made little progress today Painting the air cleaner less its 17-1/2" cover that still missing; I used the VHT SP134 "Ford Light Blue" and hope to withstand the engine heat...Today I also visited the local Junk yard but no success in finding an air cleaner cover that would fit . I have the decal for it though..:)
The Radiator that my 1986 Bronco XLT came with does not look like the original radiator; it's a 3 row copper/brass type. I filled it with water and discovered 2 leaks which I fixed. Flushed it a few times and a lot of stuff came out; I noticed that the tubes are very thin and I'm kind of hesitant to re-install it but I do not know what radiator to install. The Ford parts listed the OEM radiator for about $360 on their Website but after I paid for it I was told that Ford discontinued the part.. As to the aftermarket radiators, I do not know what to select. Any suggestions for a good radiator? I better pay once and cry once...
Attachments​
Emelio
Emelio
Lynnwood, WA
351W, 5.8L engine start up...
I've inspected each of the engine cylinders with a borescope and they appeared clean with almost no carbon deposits.Spark plugs looked great and after a poured some transmission oil in each cylinder I manually turned the engine a few times;could not detect any problems so I assume that the engine is in good shape. I discovered that engine has 040 pistons so it appears that it was rebuilt sometimes before. I need to do a vacuum and a compression test, do I need to put a cap on all the vacuum trees on the manifold? The smog pump and all the vacuum hoses were removed...
Tnx
Yo Emelio
1986 Bronco & F Series EVTM @ https://www.garysgaragemahal.com/1986-evtm.html
by Gary!
Vacuum Leak Test; On an idling engine check for vacuum leaks using a mechanic's stethoscope, or a ~3' garden hose section.
On COLD ENGINE only, use propane torch w/rubber hose attached, UNLIT or spray carb cleaner, when it gets to the the leak the RPMs will rise.
Vacuum Gauge Diagnosis by Craig @ Reading your vacuum gauge
Suggest buying a vacuum gauge, best low cost test and MPG helper you can spend $ on;
pic; "...I have a vacuum gauge mounted right in the dash of my truck. I use it to also help determine the load my engine is under while driving, and to estimate fuel economy..."
Source: by William T at http://www.fordf150.net/images/mytruck/vacgauge.jpg
See my post here @ Is it just a vacuum leak?!
for HOT LINKs to each below;
Also check:
vacuum hoses;
EGR Valve
acronyms (not nec. for your year/engine)
A/CL: Located in the air cleaner
A/CL DV: Air Cleaner Diverter Valve
A/CL BI MET: Air Cleaner Bi-Metallic Valve
A/CL CWM: Air Cleaner Cold Weather Modulator
ACT: Air Charge Temperature Sensor, prior to 1992
ACTS: Air Cleaner Temperature Sensor
ACV: Air Control Valve
AIR: Thermactor, short for Thermal Reactor. CA vehicles are installed with it as standard. Air Injection Reaction is what it stands for.
AIR BPV: AIR BPV is the AIR Bypass (AIRB) Valve; also called the TAB (Thermactor Air Bypass) Valve
BV: Bowl Vent (on top of the float tanks)
CARB: Carburetor
CBD: Closed Bowl Distributor
CPRV: Canister Purge Valve
DIST: Distributor
DPFE: Differential Pressure Feedback
DV-TW:Two Way Delay Valve
EFCA: Electronic Fuel Control Assembly/ (Fuel Pressure Regulator (FPR)
EGR: Exhaust Gas Recirculation
EGRC/EGRV: EGR Vent/EGR Control
EXH HCV: Exhaust Heat Control Valve
EVP: EGR Valve Position
EGR: Valve Position
EVR: EGR Vacuum Regulator; also called EGR Vacuum Solenoid
FLTR: Filter
FPR: Fuel Pressure Regulator (check vacuum line)
HEAT VLV INT: Heat Vacuum Control Valve Intake, (next to carb)
HICV: Hot Idle Control Valve
IAT: Intake Air Temperature Sensor (Air Charge Temperature (ACT), prior to 1992
IVV: Thermactor Idle Vacuum Valve
LCV: EGR Load Control
MAN VAC: Manifold vacuum-Vacuum source; usually ref. to as Vacuum Tree atop intake manifold]
MAP: Manifold Absolute Pressure
PCV: Positive Crankcase Ventilation
PURGE: Vapor Canister Purge Valve
PV: Ported Vacuum
PVS: Ported Vacuum Switch (PVS) Valve
S: Spark port
SA-FV: Separator Assembly Fuel/Vacuum
SOLV: Thermactor Solenoid Valve
SV CBV: Carborator Fuel Bowl Solenoid Vent Valve
TCAC: Thermostatically Controlled Air Cleaner
TCP: Temperature Compensated Accelerator Pump
TK: Throttle Kicker
TVS: Throttle Valve Solenoid (aka Solepot, Dashpot)
or
TVS: Temperature Vacuum Switch
TVV: Thermal Vacuum Valve
or, TVV: Thermostatic Vacuum Valve (aka Ported Vacuum Switches; Thermal Vacuum Valve)
VAC: Vacuum
VCKV: Vacuum Check Valve
VCV: Vacuum Control Valve
VDV: Vacuum Delay Valve
V CK V or VCV: Vacuum Check Valve
VOTM: Vacuum Operated Throttle Modulator
VRDV: Distributor Vacuum Delay Valve (VDV, VRDV, DV-TW)
VRDV: Vacuum Delay Valve (VDV, VRDV, DV-TW)
VRESER: Vacuum Reservoir (coffee can style in earlier years; replaced by plastic style)
VRESV REST: on earlier years such as SEABRONC's 83 is a Vacuum Restictor/delay valve, it delays vacuum for a certain amount of time
VRV: Vacuum Regulator Valve
WOT: Wide Open Throttle Valve
Emelio
Emelio
Lynnwood, WA
Thanks for the detailed response miesk5; I've found an old a Harvey E. Hanson vacuum tester on eBay ;I hope is good enough, it will be here today or tomorrow...
Molokai Sinbad
Hawaii
Aloha miesk5! Great Wisdom, Noticed in one of your pics of the lower EFI intake, had a sensor located between the #6 and #7 Injector. Swapped out my stock 1986 air filter housing for a 91 housing to get it away from the exhaust manifold and found the sensor missing after removing the mounting plate. Most references only identify the Air Charge Temp Sensor between #5 and #6 Injector. What is the missing sensor and do I need it? Much Mahalo...
