No start condition 1988 bronco 302 EFI
Corsair
What happened is: I was driving on a dirt road and i hit a hole in the road (approximately 35 MPH) with my left wheels, and a violent tremor was felt through the car and my engine died instantly, check engine light came on.
I have a spark on all 8 spark plugs, and fuel pressure on the fuel rail. Engine cranks fine but no start up.
Fuel pump inertia switch has not triggered.
I have tried to pull fault codes, but my code reader isn't starting self test. only a continious soud signal and light.
I have also tried to change the ECM to a ECM pulled from a 1992 F-150 with the same engine and transmission.
I'm at a loss, what can cause this and what can i check next?
Any help appreciated
Regards
Corsair
Yo Corsair,
Scan Tool Won’t Initiate Self-Test Due to Poor Grounds, Corroded Wiring, etc.;
Source: by Jeremy M (Big '92, jermil01)
C
Corsair
Yo Corsair,
Thank you. I'm going to try that.
I'll let you know how it goes.
