BillsFan76
Next on the list of issues with my Bronco. When bleeding the air in the brakes last weekend, I noticed the 9" axle seal on the passenger side had leaked all over the brakes shoes and drum. I read online about replacing the axle seal and it seemed pretty straightforward. Everything I read mentioned using a seal puller to get that seal out of the axle housing after pulling the axle shaft out but when I went to my local O'Reillys, the guy had no idea what I was talking about and said they come right out with a flat head screwdriver. I went home and tried to get it out without doing any damage and it wouldn't budge. Didn't want to mess anything up so stopped right there.
Also, when I pulled the axle shaft out, the round spring that I believe goes inside the seal itself, was laying inside the housing. I believe it came off the seal that is on the axle itself and is pressed on. I had no plans of changing that seal because I thought the leak was coming from the one in the axle housing itself but since the one on the axle itself is the one closest to the outside, would I be right in assuming it was the one leaking? I have no way of pressing the seal and bearing back together, is that something that can be done at a place like brakes plus? I know they replace axle seals that leak when they do brake work, wondering if I brought them the axle shafts if they would press the new seal back on and just charge me for the labor. If not, what other places do that type of work? Long winded post, sorry for that. I always try to explain everything so it's as clear as mud in the end
/emoticons/[email protected] 2x" width="20" height="20" /> Thank you everyone for the assistance, I appreciate it.
Alex
Alex
