trailer wiring
jleary3rd
I have a 1990 full-size bronco and was checking to see if you need the special T-connector for connecting a 7 wire trailer connector.
yo;
Also
Trailer Harness Wiring Colors TSB 89-14-17 for 90 Bronco & F Series
Source: by Ford
TSB 89-14-17 Trailer Wiring Colors
Publication Date: JULY 14, 1989
LIGHT TRUCK: 1990 BRONCO, F-150, F-250, F-350
ISSUE: Trailer tow wire harness color codes have been revised to be compatible with SAE color code standards. When hooking up a vehicle to a trailer that has been wired according to the SAE standard, the wire color/circuits will match.
ACTION: Refer to the following Circuit Color Code Chart for the correct color/circuit usage.
CIRCUIT COLOR CODE CHART
CIRCUIT FUNCTION - OLD COLOR* - SAE COLOR*
Trailer LH Turn/Stop - LG/O - Y
Trailer RH Turn/Stop - O/LB - DG
Trailer Brake Lamp From Controller - R/LG - R/LG
Trailer Electric Brakes Solenoid - BL/BR - DB
Trailer Back Up - BK/PK - R/Y
Trailer Ground - W - W
Trailer Running/Tail - W/R - BR/W
Trailer Power (Battery Charge) - Y - O
Trailer Brake Control Feed - R - R
Color Key - Color Abbreviations
BL-Blue
BK-Black
BR-Brown
DB-Dark Blue
DG-Dark Green
LB-Light Blue
LG-Light Green
O-Orange
P-Pink
R-Red
W-White
Y-Yellow
vivalaporkchop
i have a 91 bronco and i am not gettting any power to my plug for the trailer and im not sure where or how to look for the problem. any hints or advise??
YO CHOPS,
Check Fuse 4
but since you did not mention that any ext lights are out such as brakes and turn signals,
Check for power and Grounds with a test lamp or meter using this Wiring Diagram in 87-91
Source: by Chilton
I THINK the Ground is in same location as my 96
Item Part Number Description
1 13A409 Wiring Assembly
2 N801846-S36MG *****
3 14405 Wiring Assembly
4 Locators, Position in Holes Provided (Part of 14405)
5 Trailer Tow Ground Wire (Part of 14405)
6 14086 Wiring Assembly
A Tighten to 5-7 Nm (44-62 Lb-In)
Fusible Link Location in Wiring Diagram in a 90; Fusible Link A-Brown 18ga to Rear Window Defroster; L-Brown 18ga to C202; M-Blue 20g to C202 (Engine Bay at Firewall to Dash Harness); G-Blue 20g to Exterior Lamps; W-Blue 20g to Fuel Pump Relay; N-Blue 20g to EEC Power Relay; G-Blue 20ga to Trailer Adapter; P-Blue 20ga to Splice 115 to Connector 202 & Exterior Lamps & Daytime Running Lamp (DRL); J-Green 14ga to Alternator
Source: by Seattle FSB (SeattleFSB) at http://www.supermotors.net/registry/media/854314
