Body question
HGM
Senoia, Ga, by way of Miami, Fla...
Does anyone have pictures or diagrams of how the cowl and rear quarters are held together? I'm trying to keep the pannels in tact, the best I can. I have a donor to supply those pannels and would like to disassemble at the spotwelds. But, with all the paint and seam sealer, its a bit exploratory in some areas. Might not be a preactical plan for some areas, but the diagrams I've seen just dont show the detail I'm looking for. Thanks for the help guys..
You won't find a diagram of the welds, it is more of an exploratory adventure. I have been successful at finding welds by using a flap sanding wheel on my grinder and running it along the weld line. Then pilot drilling the weld before using a weld cutting bit. Another method for finding a not so visible weld is to separate the metal as you go using a Seam Buster http://www.autobodytoolmart.com/steck-seam-buster-20015-p-11711.aspx . Just tap it along the line until it won't go any further and "wallah" you found it :D .
A picture of the tool
H
HGM
You won't find a diagram of the welds, it is more of an exploratory adventure. I have been successful at finding welds by using a flap sanding wheel on my grinder and running it along the weld line. Then pilot drilling the weld before using a weld cutting bit. Another method for finding a not so visible weld is to separate the metal as you go using a Seam Buster http://www.autobodytoolmart.com/steck-seam-buster-20015-p-11711.aspx . Just tap it along the line until it won't go any further and "wallah" you found it :D /emoticons/[email protected] 2x" width="20" height="20" /> .
:) /emoticons/[email protected] 2x" width="20" height="20" /> Well, guess I'm doing it the right way... Just wanted to make sure there wasnt a better way.. Its amazing how many spotwelds they applied to these little things..... Thanks for the info..
