95 ford bronco automatic hubs to manual
whytee95eb
ok, so my auto hubs went bad, took them out, so i bought manual hubs. iv read somewhere that i may need a kit to convert it? im not sure, wouldnt think so. and another question is on my passanger side, when i tried to put the hub in, the shaft that slides in the hub seemed bend, as it was pushing the hub along the side of the housing. now, another concern is sometimes..not recently howerver, when i turn either direction and im coming back to forward, my wheels dont want to follow through the correction, as if they were stuck turning or my alignment was off, just replaced a radius arm bushing, maybe that helped. any suggestions or comments would be greatly appreciated:) 95 351 EB
W
whytee95eb
also, i feel vibrations coming from my drivetrain(somewhere) when i reach over 40mph and it wants to shift to od, and when i excelerate it vibrates. if i punch it or go really slow it doesnt do it. i avoid od and it still does it. iv had my u-joints checked and there was no play, so im not sure. i love my bronco, engine runs so good, not sure if its a money pit though, i thought maybe some of you would have similar problems. im dumping the necessary funds in to it to get it perfect before the first snow, so direction would be AWESOME!!
50joe
Trenton NJ
Not sure if its the same thing, but I have run across a few fords, (mostly crown vics + G Marquis), that would get a strange vibration right befor shifting into overdrive on slight acceleration. The cure was to flush the trans fluid and pop in a new filter. cleared it up every time. Don't know if thats the case with yours, but something to check into.
bprescott89
