What size tires can I get on my stock OJ bronco
jacks wasted life
Indiana
I just purchased my first Ford Bronco it is a 1995 and it is stock. I am looking to replace my stock p235/75R15 with a bigger tire looking into 31/10.5R15 but I dont want to buy them online and then have clearence issues. It may be a stupid question but Im not going to spend 140.00 a tire and then have rubbing. If anyone can help me with this question that would be great!! [-o<
chuckles1856
Lift it first and then buy the tires ;-)
I'm not sure but someone will have a clue on here.
JCFindley
Kansas City
You will be fine with 31/10.5s. No mods required. You can go as high as 33x12.5s if you put spacers on the front bumbers. You will get a little rub on tight turns from arms during with stock rims but it generally won't hurt the tires and can be fixed by not turning quite so tight. I have 32x9.5s and have had no fender rub at all and I know there are folks on here that run 33s without lift. I put pics of my 32s to show what clearance i have with them.
JC
jacks wasted life
jacks wasted life
Indiana
JC
Thank you for the help I like the 32s that you have on there and think that may be the way I go!
Krafty
Ontario Canada
33's fit on the 70's to 91 f 150's and broncos without lift, but 92 to 96 need a shim in the front bumper to clear the tires. other than that they fit like a glove
50joe
Trenton NJ
I just upped to 305/70/16's and they clear better than the 32x11.5x15's i had turning wise. But my front bumper is spaced out an inch, and i went from a stock rim (15x7) to a 16x8 1/2 <equal to a 33x12.5 almost
