New Engine Advice
Treg
Iowa
Well after tons of work over the last 6 months the engine is done. It is 351W in a 93. Should I replace it with the same, a crate, anything else recommended or suggestions? I may try and do it all myself but if that ends up being a time commitment I don't have then I will purchase it and have someone else put it in. My current engine has a supercharger but that is not going back in I think. Not sure about stage 1 or 2. My thought is that I want horsepower and I want to spend around $3K. Thanks for your help!
3k is a very tight budget and if you want HP... a fresh 351 with a power-add'r  is the answer. Anything built up is going to cost $4-6k. I would like to be proved wrong but thats just my experience as I have been pricing out engines for my own Bronco.
My 90 351w was done by a local engine builder. Complete bottom end rebuild he bore the motor 040. And put in a mild cam. And assembled the rebuild ran about 2000 and the aluminum heads were another 800. I have plenty of power now. If you have the supercharger already get it done locally and have them put it on while it's out.
Thats a better answer then what I can come up with.
