New guy question
Juan2three
I am new to the "zone" and inexperienced in using "forums".  What are "warnings" about?......Is there a list of rules? (where)........If I post a topic on one forum can I post the same topic on another forum (hoping for more exposure)?.........Thanks
It is a problem area of the forum that we are working on.  Warnings are for the moderator to keep track of rules violations,  the rules were visible when you signed up for an account. We are working on updating them and making them more easily accessible.  We only allow posting of a problem in one forum, if we decide it is posted in an inappropriate forum, we will move it to a more appropriate location.
For the present, you will be notified if you have any what we consider forum bad behavior along with a warning point.  Basically, treat other forum members the way you would like to be treated.  No arguments, no badmouthing, no trolling, no ganging up on someone, etc. If you have something valid and constructive to add to someones forum question, you are welcome to add your 2 cents at any time.  I always look at it this way, "There is more than one way to skin a cat", I do something one way and you may do it another way, as long as in the end the cat is ****** they both accomplish the same thing.  Generally I don't insert my comments in another discussion unless I have something positive to add that may help.
Thanks for your question.
Hope that helps,
Yo Juan2three,
Next time, please fill out your Signature with year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. for better responses.
Click your name in right black panel in upper right;
In pop up,
Click, My Profile
Click, Edit My Profile in right side black panel
In left panel, Click, Edit Signature
Enter info
Click, Save Changes
To post a pic from your PC, TABLET, etc., just below the reply box in lower right corner, click More Reply Options
Screen will change
See Attach files
pick out the pic
Click Attach This File
or click, Try our advanced uploader (requires Flash 9)
Our sponsor, Jeff at the Bronco Graveyard has offered a 2% discount to members of The BroncoZone for on line orders. To get your discount, enter the discount code BZMEMBER. Also you must include your BroncoZone User Name with the order.
http://broncograveyard.com
Here are some wiring diagrams (partial, 86 through 96) and Technical Service Bulletins, (80 through 96) @ http://www.revbase.com/BBBMotor/Wd
96 Bronco-F-Series Workshop Manual (PARTIAL) by FORD via
http://www.diesel-dave.com/vehic/manual/stj/stjleft.htm
96 Bronco Owners Guide by Hiller Ford @ http://www.hillerford.com/resource_library/owner_manuals_pdf/1996_owner_manuals_ford/96bronco.pdf
96 Bronco Dealer Brochure by Ford via me @ http://www.supermotors.net/registry/media/877777
BTW, I replied to your outside rear-view mirror question and saw that you have a 96 so, check with VIN at dealer or on-line @ Ford; for the Speed (aka Cruise) Control recall; this recall has a life of its own and still undergoing changes; deals w/speed control deactivtation switch mounted on master cylinder; fires have been reported. RECALL - MULTIPLE VEHICLE LINES - SPEED CONTROL SYSTEM MODIFICATION.
