Ford has used the same 5-on-5-1/2 bolt pattern for ages and I haven't heard anything about them changing it. You can pretty much expect any ford 5-lug rim to fit and 5-stud rotor or drum. Some specifics would sure help a lot in figuring out just what you're trying to run or swap and we can give you a better answer, but without any more info all I can give you is the basics which pretty much say that your average ford 15", 5-lug rim will fit pretty much any ford 5-stud drum or rotor. Provide more info & me or someone else can give you a better answer.
Rims from other manufacturers generally don't fit, unless you can find the 5-on-5-1/2 pattern that someone else is using but most companies like to be real unique about ther bolt patterns so no, I don't know offhand of anyone else's rims that will fit the Ford pattern right off the top of my head.
