- Joined
- Dec 13, 2007
- Messages
- 1,537
- Reaction score
- 13
Ok I hear your frustration...it is frustrating.
Go to an Advance Auto parts or other Parts place, or where you bought your battery or starter and have them do a load test.
This will tell if the battery is getting a great draw from the starter, or if the starter is ok and the battery is weak. If you have changed the cables, you can eliminate that from the problem list.
you did say after wrapping the exhaust and putting a shield on the starter the problem went away for awhile. That indicates the starter is bad.
Good Luck.
Good Luck.
