water leaks in my cab
SC831
santa Cruz California
i have a horrible leak in my passenger side of my cab every time it rains its looks like somebody poured a 1/2 gallon of water on the floor only on the passenger side its leaking from above the kick panel
at first i thought it was my windshield but i resealed it so it cant be
has anyone had this same problem?
i have a horrible leak in my passenger side of my cab every time it rains its looks like somebody poured a 1/2 gallon of water on the floor only on the passenger side its leaking from above the kick panelat first i thought it was my windshield but i resealed it so it cant be
The leak could still be the window. Did you do the seal around the top? Check for cracks in the drip channel. does it happen when you are not driving? like after a rainy night and before you start driving?
You may have to remove the dash cap and have someone soak the truck with a hose while you look for the leak source.
andre
gatineau hill quebec
ad this prob on mine
the alse on each site of the inner fender a drain
where the grill like cover near wipper arm water get in there
if drain are block
will make it rust thend rain can't drain
some water get in cab
best bet try hose inside grill where wipper are working you way to top of winsheild
Sufferedformula
