twin stick transfer case install
project71
I have removed the body of my bronco off of the frame. I want to use this chance to install a twin stick transfer case lever. Will it fit in the factory hole of the body or will it have to be enlarged?
mustanggarage
Iowa
Mine had to be cut larger i am running an ax15 transmission so I can’t say if all of them require it, but I do know that cutting the hole too small leads to a lot of headaches trying to get it to work properly lol
Motech
Santa Cruz, CA:
You going with the Allied? It will fit, but the tunnel will need to be expanded, and MAN is it tight! A body lift as little as 2 inches will make your work much easier.
chrlsful
S. Amherst, MA 01002-1827
many do the on'n off'n on again to 'get it'. I used the case to do so. 1st - a measurement block face to 'tower' or stick, cut a lil, brought case up for view, marked, droped dwn case (transmis jack & lift are such great inventions). Cut a lill. Brought back'n fit well. Do not cut too much as a boot may not cover / stretch. Then attach boot/estachon. To B really happy? I'm gunna make a huge plate for that & my transmission stick. It will B like the early imports. The boots will come up w/the single large plate. Some speed nuts, 3/8th bolts and a weather strip for noise'n H2O intrusion will complete (THIS could B done w/all the 'lift' in the plate)..
tsebalj
