Transmission Linkage
scubscout53
Hixson, TN
my 96 Bronco, 351 Windsor, when I put the column shifter in"D" I have to bump it up slightly or it starts in 2nd gear and doesn't shift out of it. I dealt with it since I bought it four years ago but recently it started jumping into neutral. Hoping it's a simple adjustment. I looked where the linkage connects to the transmission but don't think I can do anything there so I assume I'll have to be a contortionist and get under the column?
Yo Scuba Scout
See https://diesel-dave.com/vehic/manual/stj/stj71a24.htm
Shift Concerns: No 1st Gear In Drive, Engages In Higher Gear
Possible Component​
Reference/Action​
215 — ELECTRICAL ROUTINE
Powertrain Control System
  • Electrical inputs/outputs, vehicle wiring harnesses, powertrain control module, shift solenoid 1, shift solenoid 2, transmission range sensor
  • Run On-Board Diagnostics. Refer to Powertrain Control/Emissions Diagnosis Manual for diagnosis. Perform Service Manual Pinpoint Tests A and D using the Rotunda Transmission Tester 007-00085, Cable and Overlay 007-00107 and the Transmission Range (TR) Sensor Cable "B" (MLPS Manual Lever Position Sensor Cable) 007-00086 or equivalents as outlined in this manual. Service as required. Clear codes, road test and rerun On-Board Diagnostics.
315 — HYDRAULIC/MECHANICAL ROUTINE
Shift Linkage (Internal/External) or Cables, Transmission Range (TR) Sensor
  • Damaged, not connected, misadjusted
  • Inspect and service as required. Verify linkage adjustment as outlined. After servicing linkage, verify that the transmission range (TR) sensor is properly adjusted. Refer to In-Vehicle Service in this section.
Main Controls
  • Bolts not tightened to specification
  • Retighten bolts to specification.
  • Gaskets damaged, misaligned
  • Inspect for damage and replace.
  • Shift solenoid 1, shift solenoid 2 stuck or damaged
  • Refer to Electrical Routine No. 215.
  • Solenoid regulator valve, 2-3 shift valve, 3-4 shift valve, D2 valve — stuck, missing, misassembled, damaged
  • Inspect for damage. Service as required.
  • Air bleeds for S1-S2 circuits missing
  • Inspect for damage. Replace case.
  • Wrong components used in rebuild
  • Verify that proper components were used. Service as required.
Mechanical
  • Band servo, clutches damaged
  • Refer to proper disassembly procedures in this section.
For diagnosis related to a specific gear, use Transmission Tester to determine gear​
Refer to the following routine(s) for further diagnosis
●No Shift 1-2, Routine 220/320
No Shift
2-3, Routine 221/321
No Shift 3-4, Routine 222/322​
Reverse Ring Gear
  • Damaged gear lugs to reverse carrier
Low One-Way Clutch
  • Damaged, misassembled
  • Inspect for damage, proper assembly. Service as required.
Shift Concerns: No 1-2 Shift (Automatic)
Possible Component​
Reference/Action​
220 — ELECTRICAL ROUTINE
  • Electrical inputs/outputs, vehicle wiring harnesses, powertrain control module, throttle position sensor, vehicle speed sensor, shift solenoid 1, shift solenoid 2
  • Run On-Board Diagnostics. Refer to Powertrain Control/Emissions Diagnosis Manual for diagnosis. Perform Service Manual Pinpoint Test A using Rotunda Transmission Tester 007-00085 and Cable and Overlay 007-00107 or equivalents as outlined in this section. Service as required. Clear codes, road test and rerun On-Board Diagnostics.
320 — HYDRAULIC/MECHANICAL ROUTINE
  • Damage, misadjusted
  • Transmission Range (TR) sensor damaged, misadjusted
  • Inspect for damage. Service as required. Verify linkage adjustment as outlined. After servicing linkage, verify that the transmission range (TR) sensor is properly adjusted. Refer to In-Vehicle Service in this section.
Main Controls
  • Shift solenoid 2 malfunction
  • Refer to Electrical Routine No. 220.
  • D2 valve, 1-2 shift valve, 1-2 manual transition valve, intermediate clutch accumulator regulator valves, springs — stuck, damaged, missing or misassembled
  • Air bleed for shift solenoid 2 circuit damaged or missing
  • Wrong parts used in rebuild
  • Verify that proper parts were used.
Intermediate Clutch Assembly
  • Assembly
  • Air check clutch assembly as outlined in this section.
  • Seals or piston damaged
  • Friction elements worn, missing, damaged, misassembled
  • Ball check stuck/missing
  • Feedbolt torque incorrect, leaks, missing
  • Inspect and retighten bolts as required.
  • Cylinder assembly outer diameter/case bore damaged, leaking
Intermediate One-Way Clutch Assembly
  • Cage/sprags damaged, improperly assembled on inner race
  • Improper components used in rebuild
  • Verify that proper components are used.
S
scubscout53
Hixson, TN
I think my problem would be in this category but I don't have the manual to look at the procedure to adjust:
I've seen videos where there are two screws under the column that can get loose. I'm going to check them also.
tsebalj
