RICASINO
Las Vegas
I'm new to bronco zone but have read lots of your great information for repairs on my rig.
My 1stbronco restore was a 1966/67 model year frame off and it was bad to the bone ( wishing I still had it), then a 1989 , 5.0 6in rancho lift on 33's (x wife has that one), then 1994 total stocker with a 4000.00 stereo that came with it, traded that one in for work a truck. Now my 1995 (everyone calls it OJ), I've had it for 8 years and did something I never thought I'd do. At 1st I installed rancho 8 in lift but with 2wd ifs, not digging on that I removed all of it but left the radius arms and 2wd ifs.
Fun projects. What is your plan now?
Yo RICASINO
ASAP, find out if speed control recall work, if equipped was completed. If you still have concerns about Recalls, please contact the Ford Customer Relationship Center:
US: 800-392-3673 | CA: 800-565-3673
Note: 3673 spells "FORD" on phone keys
For the hearing- or speech-impaired: Please contact the Telecommunication Relay Service by dialing 71
1995 Bronco Dealer Brochure @ 1995 Ford Bronco
1995 Bronco Drivetrain, Powertrain Service Manual - Google Drive
1995 Bronco Chassis, Service Manual - Google Drive
To switch between folder list & grid views, click the button to the right of the "DOWNLOAD ALL" button in the upper right corner of the window) by HawkDriver
Haynes Red Manual for 80-95 Bronco & F Series @ Hanes guide 80-96 bko f series.pdf via BroncMom
R
RICASINO
Las Vegas
Sorry so long for reply but I've been nursing a broken right leg, after rods, screws and those plates and screws besides the hurt it takes time to learn how to be like it was before. Anyways on that 95. I installed f150 ifs along with rancho extended radius arms. I have 6in Rancho Coil springs to install. Im wondering what would be the best (strongest) drop brackets the pivot arms, I had rancho but they seem to flex under pressure or that's what they look like they will do. Also I want to trick out rear suspension. I was thinking 4 link coil over?
I remember some time ago an elliptical spring for the rear. It looked like rear leafs, only the front half attached Infront of the axle and at the axle in stock position and some kind of coil over shock in the rear. Any info and or help would be appreciated. I will try and send out some pics
Jimbo26
Texas
Welcome aboard and 🍺here's to hobbling around less.
bigd1948
