Intake
Grizz
Sacramento California
Is it possiable to take the upper intake from say a 94 Ford Mustang 5.0 with the single port throttle body to use on my 5.0 Bronco.
I am looking to upgrade my throttle body and i find a lot more in the single port type versus the twin like on the trucks.
 Also if and when i upgrade the throttle body do i have to increase the flow rate or upgrade my injectors to match the throttle body need?
G
Grizz
By the lack of replies i figure nobody has thought or have tried this.
 So my other option i am thinking would be to track down the intake of say a Lighting truck.  i know these trucks have a better motor option than my truck.
yo Grizz,
Lightning intake sounds good;
see this;
Saleen Vortech pic in a 95 5.0
Source: by JoeBob101
99 Escalade 6.0L Installation in a 95
Source: by Late Model Man (Rick, Big Nasty, Beast, latemodelman
"...Another (but different) ghettofab K&N
Ok I have seen the installs for the twin tube intakes but never for the singles, it's really simple, so here goes:
***It was late so I didn't get measurements but I can post up whatever you want upon request***
First off, I got a filter for a '99 Escalade 6.0L. It has the hole for the O2 sensor and is plenty big for a 5.8
order for it to work you will need to machine a stack that the filter clamps onto and that will bolt up to the MAF sensor housing. I used a 3/4 chunk of alum, 2 holesaws and a lathe to chamfer it and a mill for the 4 bolt holes. (I'm sure a drill press will work fine too)
http://www.supermotors.net/getfile/453100/fullsize/img_1427.jpg
In the bottom of this picture you can see the aluminum bracket that holds the MAF housing to the coolant tank holder (technical term)
http://www.supermotors.net/getfile/453099/fullsize/img_1425.jpg
http://www.supermotors.net/getfile/453102/fullsize/img_1429.jpg
Now you could stick with the factory air tube like I did for a while or you could find some pipe and make a cooler looking one like I have now. 3.5" dia. pipe, painted it, added the sticker. I got the silicone black things at a hardware store and have no idea what they're called, but they came with the hose clamps.
http://www.supermotors.net/getfile/453097/fullsize/img_1422.jpg
http://www.supermotors.net/getfile/453096/fullsize/img_1421.jpg
http://www.supermotors.net/getfile/453095/fullsize/img_1420.jpg
Air Tube Mod in a 93 5.0 Centurion
Source: by bigjims4x4 (Big Blue) at http://www.supermotors.net/registry/3022/11739
