I need Some Help, hard shifting
RedNext
Louisburg NC
I have a 1994 Ford Bronco XLT 5.8.
It Seems to be shifting Kinda hard when i'm Driving it. I was told it could be the speed sensor so I replaced the sensor on the rear axle.
That didn't work so I read up on some things and now ive replaced the two sensors on behind the front tires. Also know as the abs sensors. only cause i read that if they are bad they cause the transmission to shift hard\ guess when to shift. But it still does it and my abs light is still on.
Also my speedometer quit working at the same time as all this. I am thinking about replacing the Rang speed sensor on the transmission.
Please help any suggestions would be nice.
From RedNext
yo Red,
WELCOME!
This may look a bit too much, but imagine what Ford or a shop will charge
Try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
http://broncozone.com/topic/14269-co...&mode=threaded
A helper is good to assist in reading Codes; best is to take a cell fone vid and replay it.
Some basics;
Visual Check
Battery is fully charged & connectors and grounds are clean
Inspect the air cleaner and inlet ducting.
Check all engine AND HVAC (under hood & in /under dash) Vacuum hoses for damage, leaks, cracks, blockage, proper routing, etc.
Check headlights
Check EEC system wiring harness for proper connections, bent or broken pins, corrosion, loose wires, proper routing, etc.
Check the Powertrain Control Module (PCM), sensors and actuators for physical damage; can use these two diagrams to locate ACT, TPS, EVP above EGR), Ignition Control Module (ICM) on distributor mounted years (Ford re-located the ICM from Distr side to driver side hood hinge area on inner fender liner in 92-96); to MAP;
Sensor Locations Diagram ECT, IAT and Water Temperature Gauge Sender;
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=14698
Sensor Locations Diagram ECT & Temp Gauge sender, PCV by Gacknar
http://www.supermotors.net/getfile/265237/original/GT-40%20lower%20intake.JPG
Check the engine coolant for proper level and mixture.
Check the transmission fluid level and quality.
Make all necessary repairs before continuing
engine temperature must be greater than 50° F for the Key On Engine Off (KOEO) Self-Test and greater than 180° F for the Key On Engine Running (KOER) Self-Test.
Turn off all accessories; radio, lights, A/C, heater, blower, fans, etc. (close driver's door)
Then turn off engine and wait 10 seconds.
Do KOEO test First
KOEO
KOER
4WABS (93-96)
4WABS Self Test & Test Connector Diagram, Component Locations, DTCs, 93-96; USE THIS PROCESS! "...The 4WABS TEST Connector is red; located at the left-hand side (driver's side) of the engine compartment and marked ANTI-LOCK TEST; Light Flash Technique 1. Note: If 12V test light is not available, the amber ABS warning light also flashes during this test. Locate test connector in the engine compartment and install 12V test light between Pins C and E. 2. With the ignition off, jumper Pin E to B. 3. Turn key to RUN position. 4. Remove jumper between Pins E and B after 5 seconds. 5. Count light flashes of test light or amber ABS warning light..." read more; miesk5 Note; for all Resistance tests, battery needs to be disconnected; remove Negative cable at battery
Source: by Steve @ http://www.supermotors.net/registry/media/255501_1
Post any Code(s) found
PSOM (speedo);
buying any parts;
This problem could be caused by a # of things;
bad vehicle speed sensor (VSS) (also called ABS,, DSS sensor) on the 8.8 (rear differential)/ or corroded Connector/ wires inside connector;
or cruddy/damaged tone ring in the 8.8.
bad 4WABS Module - It is located below ws wiper fluid/coolant recovery tank. So, the connector can be corroded by leaking fluid
bad PSOM (Speedo)
bad wiring/shorts /connectors from VSS at firewall, at 4WABS Module and /or at PSOM and then onto the PCM
The locations of the connectors along the path from VSS to 4WABS and up to Instr Cluster & PSOM are;
C404 VSS On rear axle sensor (A7) Terminals: 02
C205 LH rear of engine compartment, in safety wall (Fire Wall) Terminals: 24 In-Line
C202F & M LH rear of engine compartment, in safety wall (A8) Terminal: 7 In-Line
C119 LH front corner of engine compartment on 4WABS control module (E10),Terminals: 40
O/LB to:
C252 Programmable Speedometer/Odometer Module (PSOM), Behind top LH side of I/P, on PSOM (A7) Terminal: 12 Color: B at Pins 4
LG/Y to Splice S107 Engine control sensor harness, from C119 near T/O to G101 (G101 RH side of Radiator support); to PSOM Pin 5
C202 F and M
and spliced to Ground G100 (BK)
G100 & G104 (tied together in diagram) G100 @ LH front of engine compartment, on upper radiator support
G100 Serves Component:
Fuel Pump Module
Inertia Fuel Shutoff
Misfire Sensor
Misfire Sensor Shield
Output Shaft Speed (OSS) Sensor
Powertrain Control Module (PCM), 5.0L
G200 Behind bottom of RH cowl panel
Serves Component:
Air Bag Diagnostic Monitor
Electronic Shift Control Module
Instrument Cluster
Remote/Keyless Entry Module
Speed Control Servo/Amplifier Assembly
From PSOM Pin 7 (GY/BK) to Splice S246 Main harness, near T/O to speed control amplifier to
C185 PK/O @ PCM 5.0L Powertrain Control Module (PCM) LH side of safety wall, on powertrain control module (PCM) (C10) Terminal: 104 Color: GY
C185, 5.8L Powertrain Control Module (PCM) LH side of safety wall, on powertrain control module (PCM) (C10) Terminal: 104 Color: GY
C185 @PCM to C202 F and M
Splice 216 to Ground G200, Instrument Cluster ground is inside passenger side kick panel
and on to C185 @ PCM PIN 58 (GY/BK) and from Pin 46 to MLPS (TR) Pin 2
Verify PCM & MLPS wiring & Pin numbers using following WIRING DIAGRAMs by Ford via Steve83
PSOM Wiring Diagram for 96 Bronco;.93-95 similar by Ford by Steve @ http://www.supermotors.net/registry/media/95931_1
Here is ONLY a SHORT EXCERPT of the Pin-Point Testing Process by Ford;
Power Distribution Box (Located under the hood on the drivers side fenderwell, on driver's side of the air cleaner housing)
and check **** FUSES H & S
Cab Fuse panel @ http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=36283
Check Fuses 8 & 18 in Cab fuse block (lower left of dash by driver's left knee)
If no 12 v on Supply Side of each; look in Power Distribution Box and check **** FUSES J & S
Speed Input Signal Test @ PSOM in 93-96 Bronco; "...NOTE: Only wiring harness end of connector is to be probed. * Connect Rotunda Digital Volt-Ohmmeter 014-00407 or equivalent to Pin 4 (speed in ) and Pin 5 (speed in -). * Does the voltage increase smoothly and continuously from 0 to approximately 3.5 volts as vehicle speed increases from 0 to 48 km/h (0 to 30 mph)? OR: If available, a frequency counter may be connected to Pin 4 (Speed in ) and Pin 5 (Speed in -). Does the displayed frequency of the signal increase smoothly and continuously from 0 to approximately 667 Hz at approximately 48 km/h (30 mph)? OR: * If neither a voltmeter nor frequency counter is available, vehicle speed control may be used as a good indicator. If it works normally, then the speedometer module is at least receiving a speed input signal and the wiring and sensor & tone ring can be assumed to be good.
This is tuff to do; suggest using str8 pins to back probe the connector
PSOM Pointer Waiver TSB 96-21-11 for 92-96; "..The speedometer needle may waver and or a light surge may occur on some vehicles..." read more
Source: by Ford
This also addresses the tone ring & PSOM unit
EXCERPT; ISSUE: The speedometer needle may waver and/or a light surge may occur on some vehicles when speed control is used at highway speeds between 80-113 km/h (50-70 mph). This may be due to slight dents/chips in either the exciter ring or the Vehicle Speed Sensor (VSS) and air gaps between the VSS and the exciter ring.
ACTION: Replace the Programmable Speedometer/Odometer Module (PSOM) if required. New PSOM's come with increased immunity to system variability. Refer to the following Diagnostic Procedure for details.
DIAGNOSTIC PROCEDURE
BRONCO/F-SERIES - Perform normal PSOM diagnostics per Pinpoint Tests "H" and "J" of the 1996 F-Series/Bronco Body/Chassis Service Manual, Pages 13-01-30 through 13-01-32 and Pinpoint "B" of the 1996 Powertrain/Drivetrain Service Manual, Page 10-03-11.
Any slight dents, chips, etc., in either the exciter ring or VSS will create needle waver. Measure air gap between the VSS and exciter ring. It should be 0.38-0.51mm (0.015-0.020"). Check exciter ring runout per the same ring gear backface runout procedure of the appropriate model 1996 Powertrain/Drivetrain Service Manual, Section 05-00. Make sure the exciter ring is mounted correctly to the ring gear. If runout is more than 0.1mm (0.004"), perform the differential runout check per the procedure in the appropriate model 1996 Powertrain/Drivetrain Service Manual, Section 05-02A or 05-02D, to find cause and repair as needed
Tone Ring Inspection; "Take off the rear diff cover. Check the Ring Tone gear. It is located on the left hand side of the ring gear. Look to see if any of the teeth have been notched (from debris floating around in the diff.) Usually a spider gear. If the ring tone gear has been notched, it will need to be replaced to fix your speedo reading. Jack it up and rotate the tires to look for the teeth to be notched/broken/bent..."
Source: by Bighibbi
My 96' symptoms were PSOM ERRATIC, swinging at speed; and 4WABS Amber bulb lit as well as CEL lit; the 4WABS Module's microprocessors finally burnt-out. I had one go bad and 2 yard Modules were also bad; so I jumpered the Module out as Steve & Turbo Ghost describes below.
To bypass the 4WABS module @ it's harness's connector & feed the ABS signal directly to the PSOM,
Disconnect module (under coolant recovery /ws washer tank) & in connector, "...jumper 14 (CKT 530, LG/Y) to 21 (CKT 519 (LG/BK) & 39 (CKT 491 (O/LB) to 22 (CKT 523, R/PK)...";
http://img.photobucket.com/albums/v252/turboghost/ABSConnectorw-jumpers.jpg
tsebalj
