Gearbox is not lining up
BRudd
New York
Hi all, I am in the bottom of the 9th of restoring a 77 Bronco. We installed a new galvanized frame to the Bronco and everything has gone somewhat smoothly expect, the gearbox is not lining up. It's a couple of inches off.... any suggestions? I am expecting to the worst but if you have any quick fixes it would be greatly appreciated. I will get more picture of it tomorrow but any help is appreciated.
chrlsful
S. Amherst, MA 01002-1827
I C a stick that looks fine in middle pic. Did not look @ others.
What's the problem ?
Never used this frame U speak of but the co.s took dementions offa an orig rig, should B fine. What R U swappin in? 3.03? D20? D30? non standard? what abt DS length? Any holes pre-drilled in frame 4 mounts? Gotta give more info than that...better info = better answs 8^ )
chrlsful
'S 2 wks now, He;s really out.
The shift tower wuz 'right there' for the
tunnel hole so not sure the issuel... mate
w/bell?. "expecting the worse"? May B justa
wiggle, wiggle'n it went in?
Wdtdls
