Easy Delay Wipers
highboy73
FORDing thru life
morocco,indiana
for ya'll guys that want the delay wipers i have a 1978 harness in my truck and i took the switch and black box of an 84 ford truck plugged it in and for 10 bucks at the bone yard i had delay wipers
Col Klinx
I could go for some delay wipers on my 78
Whats this black box that you mention? wiiper control for the newer trucks?
Then do ya just splice it into your old wiper switch.
Ziggy
Riverside, Ca
They box is the delay control and it plugs in between the the exsisting harness and the wiper switch. No splicing or cutting wires required. You'll also need the delay wiper switch or else it will not work. The wiper delay switch has a seperate ground wire that must be attached to the frame some place. I did this to my '79 a while ago and even though I live in SoCal, I'm glad I have it. Cost me all of $5.00 out of a junkyard. Now I look for them and pull them out when I find them and give them away.
You should be able to find those on any 80 - 86 that had the delay option. I've collected a couple myself.
G
Guest
Guest
awesome, I 'll hatfa check it out, I see a trip to the junkyard in my future.....
H
highboy73
FORDing thru life
morocco,indiana
glad to help with some help.they are right just plugs right in and you got it.takes awhile to get used to though
Root710
