Aluminum wheel widths
Jeff Ogden
Dayton Ohio
My 88 has the styled steel wheels with the trim rings and center caps that are 8 inch wide,I have seen a slightly narrower version that came on the 2wd trucks so I was wondering if it was the same with the aluminum wheels. I am looking at a set from a 2wd truck and look to be narrower then my wheels.
Yo Jeff,
What size tires are or will be on your 88?
Suggest https://www.tirerack.com
Go through the drill:
Select wheels,
Make Ford
 year 1988
F 150 2 wheel drive
Material; Aluminum Alloy
etc.
Then scroll through
Ok go the site and put in the info_Or check with local tire dealer that services many 4x4s, does lifts, etc.  Your 2 wd Bronco will be a hit there.
Yo Jeff,
Sorry, but my tablet or Comcast cable freezes part way through the search process.  It stops at Aluminum Alloy.
Yo Jeff,
david@holycitytransportat
